On Location - Charging setup
Mike-h
Hertfordshire, United Kingdom
  1. Limitless
Just put together a rig to enable charging whilst out and about Bashing and Speed running
(lets the fun last longer 🄳 )
Picked up a 299wh generator:
ALLPOWERS Portable Power Station R600, 299Wh LiFeP04 Battery with 2x 600W (1200W Surge)
connected to my charger with a 12v to XT60
Works really well for charging lipos (using my SKYRC T1000)
Charging a 5200mah 3s Lipo @ 5,2a only draws 70w, so should get around 4 hours of use from the unit
so even with dual charging 10000mah lipos I should get a couple of hours runtime.. enough for multiple charges.
One feature to note Discharging a battery with the T1000 and discharge unit doesn't draw wattage from the generator, so no impact on runtime
the unit will also recharge via portable solar panels if needed.. but as I live in the UK sunny days are a rarity, so probably wont bother picking them up
Have also picked up a Peli style case to transport them in..
