iLikeRCs
One tooth of my sun gear (I think that's what it's called) is slightly chamfered. All teeth have a little bit of wear. Do you guys think I should replace it right away (would need to order a spare) or is it fine? Running trencher 40 series tires on stock pinion (I run it quite hard at the moment as I run it every day and driving normally got boring after some time, double-backflips and so on). I'm worried about damaging the small gear as well If I leave it as it is and put it back in. It is hard to capture on camera, but if you look at it really closely you can see the damage
