I'll be home shortly and I'll check it out again would that be a reason why I lost reverseYou might have stripped your center diff.
or your rear diff.
When you hit the throttle does the dog bone going to the rear diff spin?
no, but my Noto does the same no reverse thing. I just have to hit the reverse multiple times and it will work. What electronics do you have in it?I'll be home shortly and I'll check it out again would that be a reason why I lost reverse
Nothing is broke or missing.You might have stripped your center diff.
or your rear diff.
This post is confusing. Do you mean you can't go backwards? Or do you mean only the front wheels spin, but not the rear wheels?Today I turned on my kraton 6s exb and only the front tires spin and I do not have reverse? What could be the issue
Reverse was not working. Also while driving forward only the front tires were pulling/driving. Like a loss of power to rear axle. Messed with controller and programmer last night, Seem to get Reverse working. I am disassembling the rear diff today to see if it's damaged or needs shimmed.. I was also told to change the rear diff fluid to a thicker fluid.This post is confusing. Do you mean you can't go backwards? Or do you mean only the front wheels spin, but not the rear wheels?
I had a feeling.Ending up being a bad rear differential, swap out with front just to check. Problem follow the differential.contacting arma Monday for replacement
Hopefully they warranty it. Bad design. Seen alot of people having issuesI had a feeling.
