Mark_k6s
Hey guys quick question can i bash my kraton with the option pinion gear that comes with the kraton v4 6s blx? Or will it cause any damage? I think its a 15t?
Many thanks
Many thanks
Thanks for the pic! Im glad to hear you have had no issues apart from being slightly big, i shall becarful when mounting the fan back on many thanks for the heads up!!Well I took it my Kraton out with the optional speed pinion for the first time today - full 30 minutes run on tarmac and short wet grass at around 3 celsius, the motor was never hot to touch.
OP I got the same heatsink and fan, whilst the fan is powerful enough to keep the motor cool, the heatsink is a little too big so you will have to bend a bit. Be careful when mounting the fan back onto a bent heatsink as the top of the heatsink is no longer flat, it can crack your fan if you tighten the fan down too tight. Ask me how I know...
