Emery Hall
- Outcast 4s
Whenever I accelerate all 4 wheels wobble up and down and it also does this in the air doing tricks. I don't know how to fix this. Any ideas?
You should both vent and balance your tires to prevent these type of issues. You should vent them first and run the truck upside down somewhere outside where water and dirt can fly out and not get something dirty. Then after you're sure they are empty and dry, you can then balance them. Should be good for a long time after that, depending on how you balance and vent them.Whenever I accelerate all 4 wheels wobble up and down and it also does this in the air doing tricks. I don't know how to fix this. Any ideas?
I have not vented them. I got the truck when i was a noob and i definitely wish i did that but i guess we all make mistakes.Did you ever vent your tires?
I will try that!You should both vent and balance your tires to prevent these type of issues. You should vent them first and run the truck upside down somewhere outside where water and dirt can fly out and not get something dirty. Then after you're sure they are empty and dry, you can then balance them. Should be good for a long time after that, depending on how you balance and vent them.
