Outcast 6s build
Vedak
SoCal
  1. Outcast 6s
Thought I'd share my build so far in a more general spot if you guys don't mind.
Hot Racing servo horn
Tidy up the wiring for fans. Joined esc and motor fans to one plug.
Protek 370tbl servo and Hot Racing front chassis brace
M2C Racing rear chassis brace
M2C Racing motor mount, Hot Racing diff cup, Tekno 12t pinion
A piece of kydex cut and screwed to the receiver box to hold my Castle Creations BEC.
I had originally purchased RPM mud guards, but didnt notice the fine print that they were RPM arm specific. So I copied the pattern onto kydex and changed the hole pattern to match factory spacing.
RPM front bumper. I left on the factory one also, because it still fit.
M2C Racing shock standoffs
SMC precision voltage alarm, mounted to a piece of kydex that I zip tied to the body support thingy?
Hot Racing axle carrier thingy
Other upgrades for the future as I wait for my blemished M2C Goliath chassis.
Will probably do M2C shock towards after, followed by Hot Racing diff cups for the front and rear.
Oh yes, blemished chassis from M2C arrived. Along with rear skid.
Noticed this on the rear diff area of the factory chassis after replacing with M2C. Would you guys say this is normal?
It’s normal for the ring gear to gouge the chassis from it flexing but it does look a little excessive though. Was that diff leaking at all?
Not from what I can tell, but it was sorta tricky, because the exterior grease that's packed in there made it difficult to identify.
M2C front shock tower and hinge pin retainers installed.
@Vedak How's the 370 servo?? In my nitros...truggy running the 170sbl steering and 155s T/B. The buggy gonna run the 155T x2. Rebuilding a Notorious 6S chassis up, curious about the 370 in the 6S SWB chassis...
Super overkill imo, just the way I like it. If you don't set the end points, this thing will move an aluminum servo mount like it's plastic. I don't regret it, but when I get my next vehicle, I'll likely go with the cheap variants everyone here uses. But I do like it a lot, and it looks cool.
