Try finding the inserts, should be slightly cheaper.Can any1 help me find some tire foams for the outcast 8s or similar that will fit? I don’t want to spend £75 on 2 new wheels and tire as I only need 1 foam. Thanks john b
I am in the U.K. I can’t find just the inserts. It’s £50 for 2 tires with inserts but all I need is 1 insert as the tires are all goodTry finding the inserts, should be slightly cheaper.
Where are you located?
I don't think they make the inserts themselves, might be alternatives though.I am in the U.K. I can’t find just the inserts. It’s £50 for 2 tires with inserts but all I need is 1 insert as the tires are all good
No I don’t think they do make them. Do you have any idea what would be similar?I don't think they make the inserts themselves, might be alternatives though.
