HI guys,
I know the outcast has a shorter wheelbase than the kraton. I sorta knew this but ordered the battery holder... It doesn't fit yay... Being specific there are two sets of dowel pin holes for the tray along with the attaching screws they aren't in the same spot along with the mounting holes. I also found my chassis was bent up front most likely because I couldn't get my front chassis brace together right because the rearward mount for the front the bolt wouldn't bottom to tighten up the counter sunk hole for some reason...
So I got new hot racing braces F+R and a new chassis
I ordered a new chassis instead of bending it back because I fear it would possibly break because aluminum work hardens like copper... So should I drill holes in the new chassis to get the new battery tray to fit? I mean the outcast battery tray is extremely good... Or I may try to 3d print an adapter out of some PETG? Ugh... Would it be worth it to drill many holes in a new chassis?
I mean with the kraton tray its garbage I kept loosing batteries from big jumps
