Outcast blk185 esc won't reset to default
Neilius707
Outcast won't go forward only reverse.when I hit the throttle the red light on esc comes on and does not move reverse and brake work no forward!! I can not get the esc to reset to default also..
Try contacting Arrma Support...
They might have some tricks up there sleeves that will do the trick..if not probably under warranty.. All the best!
Thanks.. Some how I got confused and screwed everything up while trying to program esc..about 5 times trying realized where I was going wrong and have it all set up now.. Had to go threw one by one and switch cannot get the default reset to work
