Matt_060983$
- Notorious
Looking for recommendations on the best esc setting on my outcast. Best Braking/throttle exc.... let's hear it!!
Have you run it with the default settings yet?Looking for recommendations on the best esc setting on my outcast. Best Braking/throttle exc.... let's hear it!!
Can your adjustments through radio be done on the fly?I'm running 37.5% brake, 50% reverse, #5 for punch. I might have 50% brake... can't remember now. I don't use the stock radio, so adjustments via the radio are a bit easier. I know I had 50% brake first, then on the radio I had the reverse EPA at 70-75% to make it less abrasive. But then I started running 6S and I think I set it to 37.5%.
When I was running 4S, I had the punch at 9 and it responded very predictably when going WOT up the face of a jump. When I first went to 6S, I thought it a better idea to start low with punch to put less strain on the diffs, so I set it to 3. This caused many unpredictable launches as the esc just stops sending power if your hard on the throttle. In my head, I was thinking it would limit power to a specific current level more so than stop sending anything at all to the motor. Then I increased it to 5, which was better, but still frequently unpredictable. I'll bump it up to 7 or 8 before I take it out again.
Ahhh.... Thanks, I was wondering how they would communicate to adjust settings. That makes more sense. I think the best thing for something like that is the complete castle setup. Everything is done through a Bluetooth app.The adjustments don't really adjust the esc, just adjusts the radio. Messing with the EPA much for brake kind of goofs up the esc for reverse, but it does soften the brakes.
I run a spektrum on all my trucks, just a cheap DX3C, which is old.
Yeah. At the time, I didn't have the HW program box, so it was either do the "beepathon" programming in the field, or adjust my EPA. I did the latter. Even with the program box, it's a bit of a pin getting the fan plug out with everything ziptied/in the way. Still quicker to use that though, or the EPA.Ahhh.... Thanks, I was wondering how they would communicate to adjust settings. That makes more sense. I think the best thing for something like that is the complete castle setup. Everything is done through a Bluetooth app.
Thank you that was quite helpfulI'm running 37.5% brake, 50% reverse, #5 for punch. I might have 50% brake... can't remember now. I don't use the stock radio, so adjustments via the radio are a bit easier. I know I had 50% brake first, then on the radio I had the reverse EPA at 70-75% to make it less abrasive. But then I started running 6S and I think I set it to 37.5%.
