Mital
has anyone tried putting the outcast 4x4 4s body on a 3s senton?
It's too short and probably too wide as well. The Outcast 6s body is pretty close to the same length but it again would probably be a bit too wide.has anyone tried putting the outcast 4x4 4s body on a 3s senton?
As Slick said above, it’s gonna be too wide and short. You can swap to a SWB chassis and it will fit length wise, but it won’t fit width wise. The tires will run the body pretty bad. You can swap to Typhon arms and HR hex extenders and probably pull it off.has anyone tried putting the outcast 4x4 4s body on a 3s senton?
