bigbird82
- Points
- 48
Was thinking about buying an Arrma vehicle for quite some time and as soon as the Outcast came out, I had to get one. So I purchased one and researched the forums to see what might wear out or break. Disassembled the whole thing. Put it all back together with some mods along the way. Going to take it out for a quick run this weekend to make sure everything is working good. Mod List:
New Mamba Monster X ESC w/ Black 2200kV Motor and Cooling Fan
RPM ESC Cage
Hot Racing Aluminum Motor Mount
Hot Racing Aluminum Center Differential Mount
Voltage Hobbies Aluminum Servo Mount
Voltage Hobbies Aluminum Servo Clamps
Voltage Hobbies Aluminum Steering Rack
Hitec 7950TH Servo (EPA set properly with digital programmer)
Racers Edge Glitch Buster
Hot Racing Aluminum Servo Horn
Hot Racing Aluminum Steering Bellcrank
Hot Racing Aluminum Front Knuckles with Carbon Fiber Links
Hot Racing Aluminum Rear Knuckles with Carbon Fiber Links
GKA Aluminum Chassis Braces
Custom Dual Carbon Fiber Tubes Mounted from Shock Tower to Shock Tower
Hot Racing Aluminum Wing Mount (Stock Wheelie Bar Modified to fit)
Arrma Aluminum Wing Washers
Custom 3D Printed Wing Spacers
Pro-Line 2017 Ford Raptor Body painted Gunmetal
Pro-Line Ridge-Line Front Bumper with Custom 3D-Printed Mount
RPM Skid Plates Front and Rear
Fast Eddy Bearings to replace all stock bearings
All differentials shimmed internally and externally
Tekno Orange Springs in Front, Tekno Yellow in Rear
Shock Washer Mod
De-anodized all red anodized parts, even Hot Racing Components, and polished them
RPM ESC Cage
Shock Washer Mod
