Matt_060983$
- Notorious
I purchased the Mugen Seiki & the Tekno sets of shims then Diff Fluid.. is that everything I need to shim & changed Diff fluids on all three Diffs or am I missing something??
Do you have a 2018 or 2019 model? If so you probably won't need the shims, diff shimming mainly applied to the first 2 generations of Arrma vehicles, 2015 and 2016 models that is. I really wish all these how to's would update their stuff to say this.I purchased the Mugen Seiki & the Tekno sets of shims then Diff Fluid.. is that everything I need to shim & changed Diff fluids on all three Diffs or am I missing something??
I believe Its the 2018 but tell you the truth I am not 100% sure.. is there a way to tell?Do you have a 2018 or 2019 model? If so you probably won't need the shims, diff shimming mainly applied to the first 2 generations of Arrma vehicles, 2015 and 2016 models that is. I really wish all these how to's would update their stuff to say this.
If you take diffs apart, I'd say play with em. Shim as necessary. Later models are better from what I read but why not check on your own?I purchased the Mugen Seiki & the Tekno sets of shims then Diff Fluid.. is that everything I need to shim & changed Diff fluids on all three Diffs or am I missing something??
A gasket, O rings and possibly bearings.
