TwiZted SkullZ
I know the manual can be/is a little confusing and I got some pretty good info from the included video.
Anyway,I made a step by step chart that hopefully clears things up....it did for me any way!
Setting Arrma Outcast Speed Control
1:TX is OFF....hold down the SET button then turn on the ESC button
2:Let it run thru the 10 beeps til you get the first green light
(Varibles Modes = the green lite flashes)
Variable 1 (1 beep)....is Low Voltage
LOW VOLTAGE LEVELS (1 green flash)
(Setting 1 Lipo....Setting 2 Nimh)
Variable 2 (2 beeps)...is Punch Setting
PUNCH LEVELS (2 green flashes)
(Punch settings 1 thru 4 are single beeps...5 is one long beep then 6 = 1 long beep and 1 short beep...
7 = 1 long/2 short beeps....8 = 1 long/3 short beeps....9 = 1 long/4 short beeps)
Variable 3 (3 beeps)...is the Brake Setting
BRAKING LEVELS (3 green flashes)
(1 beep = 25% braking...2 beeps = 37.5% braking (factory)...3 beeps = 50% braking)
Variable 4 (4 beeps)...is the Run Mode
RUN MODE LEVELS (4 green flashes)
(1 beep = Fwd/Rev (for racing)...2 beeps = Fwd/Brake/Rev (factory setting) )
Variable 5 (5 Beeps)...is Motor Wiring/reverse the wiring (not needed)
(1 beep = Reversed wiring....2 beeps = Normal/Factory wiring)
***IMPORTANT...SHUT THE ESC OFF AFTER EACH VARIABLE SETTING TO PROGRAM THE ESC BEFORE GOING TO THE NEXT MODE***
Hope this helps and here's a pretty good vid that explains things in further detail!
