Outcast Outcast hexes
I have not tried it, but i don't think that they will directly fit since the 4s hex pins seat so close to the bearing
i see,. no idea on those, but only lists the 4s trucks.... trying to find a direct replacement as well. the grub retainer was stripped in mine on one nut from the box.......
Same thanks for the help
anytime! if i spot a more direct alternate, i'll try to post it here
okk, so......don't know what your thoughts are on the stock, plastic driveshafts. i have been debating on replacing mine as i have 6s going through them. Arrma recently released these, a bit expensive if you are buying just for the hex though....
https://www.arrma-rc.com/part/ARA310893
