If I don’t have any bearing oil what else could I use or would it be fine after I cleaned and dried it?Remove the bearings clean lubricate and reinstall.
Yeah I have the stock bearings do you know what bearing would be good for the outcast?Engine oil is fine. You still have the stock bearings? Maybe a good time to upgrade to a rubber sealed set? Run it as is till they come in.
Thanks mate is hudy bearing oil good to go for?Jim’s bearings and team fast eddy has compleat sets
That’s fine for racer types, but to be honest, if you want the lube to last longer and not need reapplied often, just use grease. Don’t pack them full or it will cause too much drag. Just around 1/2 packed with auto grease, like Red n Tacky or Mobile 1 Red.Thanks mate is hudy bearing oil good to go for?
