Outcast Outcast no reverse
Camo
Australia
Hey was wondering if anyone can help.
I've got no reverse on my Outcast after a bashing session yesterday.
I've tried a couple of things.
I have tuned the ESC to make sure the the running mode is Fwd/brk/rev that's all good.
I've factory reset the transmitter and re bind
Any ideas would be great.
Did you check your throttle trim? There's a post in the Kraton section on the second page titled Reverse. He had the same issue, adjusted his trim back and it corrected the issue.
I agree with the comments above, move your trim to 5 o'clock and it'll fix it. At least that's what it did for me. I had no reverse at 7 where it was, I think my 2 year old moved it on me the little thuglet.
Thank you !!!
That did the trick. Feel a bit stuped :)
I’m having the same issue, after a bashing session today it stop reversing. I’ve tried setting the throttle trim to 5 o’clock but no reverse yet.
Can it be anything else?
Appreciate your insight
I figured it out my issue, I had to recalibrate my throttle settings with my ESC for some reason.
Here is the video I found on YouTube.
Great video for folks that are trying to tweak their factory settings!
I had same problem with my girlfriends big rock . I tuned the throttle trim and she works perfect now 👌 . Thanks bro 👍
