Stock pinions are crap. Drop in the Robinson #1216.The Next Upgrade would be 16T Robinson Racing Pinion and HPI 12T there are much stronger
This Monster has striped 4 Stock Arrma Pinions tell now
I can't agree moreStock pinions are crap. Drop in the Robinson #1216.
Yes I am bashing on 6SCould be.
Four is a lot...are you bashing on 6S?
A good mesh is key not only for pinion life but also good engine temps.
I agree with Rich that the stock pinions are not good.
I have a Robinson 16T...no problems thus far.
Most certainly it could be mesh and very likely. It could also be because you are doing jumps and then landing while giving it throttle.Do you think the mesh is the problem?
I don't use paper for meshing, just make sure you have a very slight amount of wiggle room. If i hold the spur gear in place I can move the pinion back and forth just a hair. This is how I was taught. All stock pinions still In tact
Some times I lose the mesh. Although, I tight the two Screws very hard
Is there a an Idea or something could help?
The stock pinions are crap. They strip, most likely nothing to do with mesh. The by feel method is really the best way to do it. Paper method is not bad, but you have to make sure you do it on at least two places as the gears are never perfectly round and likely you end up tight on one spot.
for losing the mesh, are you using loctite on the screws holding the motor?
Raji - are us using threadlocker on those screws, and letting it cure 24 hours before using the vehicle?
Rich Duperbash, looking to upgrade my stock pinion on my 6s KRATON since i have installed yeah racing dual hurricane fans!Stock pinions are crap. Drop in the Robinson #1216.
Yes indeed ?Rich Duperbash, looking to upgrade my stock pinion on my 6s KRATON since i have installed yeah racing dual hurricane fans!
Would the Robinson Racing 1216 Pinion Gear Xtra Hard 5mm 16T Mod 1 RRP be a good choice for an upgrade brother on my KRATON OR MY 6s NOTORIOUS??
