Mattalt8721
New Member
Check the ESC parameters to make sure Reverse was not locked out. Sometimes the ESC F/W craps out. And many ESC's default to Forw/Brake only. FWIW.
Next I would recalibrate the Radio' Throttle Endpoints to the ESC. Manuals in hand.
Hopefully you did this when you installed the XLX2 ESC to begin with.
If all this fails, then do an ESC reset and recalibrate the Radio to the ESC once again.
Hopefully you have the CC PC adapter or BT adapter to do this. A required accessory for ye
Yes I tried recalibration and when it goes yellow and u out in neutral.the light stays yellow, and how do.u adjust setting on ecs, other on the. To adjust I see, I bought it used so don't know what was done when it was bought lolCheck the ESC parameters to make sure Reverse was not locked out. Sometimes the ESC F/W craps out. And many ESC's default to Forw/Brake only. FWIW.
Hopefully you have the CC PC adapter or BT adapter to do this. A required accessory for CC ESC's IMHO.
Call CC if you can't sort all this out.
Sounds like I need the b link for ecs before I can do anythingYes I tried recalibration and when it goes yellow and u out in neutral.the light stays yellow, and how do.u adjust setting on ecs, other on the. To adjust I see, I bought it used so don't know what was done when it was bought lol
Sounds like I need the b link to fix this lolCheck the ESC parameters to make sure Reverse was not locked out. Sometimes the ESC F/W craps out. And many ESC's default to Forw/Brake only. FWIW.
