ARRMAgeddon
- Thread starter
- #41
Yeah i think i might need those tbone bumpers again
What goes in here?
What goes in here?
That is where you put the balance plugs so they don't get damaged. The rubber strap holds them in... Sort of.
I don't use mine because should your battery get ejected it might just rip the balance plug out.
I'm not 100 percent sure but I believe that you would need to take 4 x 4.2 to get a voltage of 16.8v as a lipo cell has a maximum amperage of 4.2 volts per cell. So it would be 4 x 4.2 x 6.7 = 112.56 watts.Good info.
Btw, with that battery, if you want to charge faster, this is what math you need.
Capacity of battery- 6700mAh = 6.7Ah
To charge within 1 hour you need 6.7A charge rate
(assuming empty to full, though for the sake of safety your LiPo's are never fully discharged by your R/C's ESC)
Power = Voltage x Current
Power = 4S (3.7V x 4 = 14.8V) x 6.7 = 99.2W
So you need to look for approximately a 100W charger. If you want to charge even faster than an hour, or a 6S pack, you need
an even more powerful charger.
I wish someone told me how to do the math, rather than me buying a basic charger, then having to buy another one again because it charges my big batteries too slowly.
The poor man pays twice...
I'm not 100 percent sure but I believe that you would need to take 4 x 4.2 to get a voltage of 16.8v as a LiPo cell has a maximum amperage of 4.2 volts per cell. So it would be 4 x 4.2 x 6.7 = 112.56 watts.
Im going to take a look there thanx bud
Might get one more LiPo for longer run time
I have about 25 minutes
I don't drain it to much ill leave some
I don't know if this thing was set to LiPo cut off lol
About an hour and half to recharged
