Outcast rear diff gone. Do you upgrade to this?
Currently reading:
LTErene10$
  1. Outcast 8s
ARA 310975 metal diff case. Just seeing if anyone has upgraded to this optional part from arrma? Ordered two of them for front and rear Diffs. Along with new gear sets to fix my exploded rear end.
Hammer Down
Addicted to 8s 🤪
Solutions
1
The coldest place on earth!! (Minnesota)
  1. Infraction
  2. Limitless
  3. Kraton 8S
  4. Kraton 6s
  5. Outcast 8s
  6. Outcast 6s
Just curious, how did you smoke a diff in this truck? Mine is 30lbs with both packs It on 12s. Both my diffs look nearly perfect.
Your not trying hard enough..
LTErene10$
  1. Outcast 8s
Internal diff gears teeth missing/broke off. Did replace diff out drive cups about two months ago. Everything looked perfect then also when putting back together. About ten more packs in and it blew wouldn’t put power to rear tires.
The damage.
Edough13
Bashing, Speed running and family!!
ArrmaForum Fan
Hospitality Award
Solutions
1
Northern California, USA
  1. BigRock 4x4
  2. Granite
  3. Limitless
  4. Kraton 6s
  5. Mojave
  6. Notorious
  7. Typhon 6s
  8. Vorteks
Not sure the diff case will help all that much. More so proper shimming of the diff and gear lash between the input and ring gear will contribute to longer life and better performance.
Armarookie43
San Antonio TX
  2. Outcast 6s
  3. Typhon 6s
I've destroyed one rear diff on one my Arrmas trucks once. The diff case split apart and damaged the internal gears. It took me months to do it on the O8S, but the case on the rear diff on my EXB K8S came loose after the like 5 runs. I had to use red loctite on the aluminum differential cases since they kept coming loose on me with Bluetooth loctite.
Armarookie43
San Antonio TX
  2. Outcast 6s
  3. Typhon 6s
FWIW.. the screws just snap off in the metal cases too. View attachment 174049
I’ve blown out two plastic ones and two metal ones.
That happened to me also on the metal ones when I was using blue loctite (bolts come loose). I'm going to inspect the them again soon and see if they didn't come loose with red loctite. Did you use blue loctite?
Armarookie43
San Antonio TX
  2. Outcast 6s
  3. Typhon 6s
I've never seen those. They are a oddball 2.5mm screw.
You guys must be hammering throttle or brake in air or are on throttle when landing. Those are a couple of the most stressful times for drivetrains. I've tried even with 12s and have not been able to make gear salad yet..
Well I have to control this thing to avoid carnage when doing 30ft plus jumps 🤣
LTErene10$
  1. Outcast 8s
Just like the center diff screws. There I believe the same if not a 3.5mm. I don’t do a lot of jumping. I mean 9 months of running hard I’m not surprised it let loose. Few months on a tp 5850 1440kv
Hammer Down
Addicted to 8s 🤪
Solutions
1
  1. Infraction
  2. Limitless
  3. Kraton 8S
  4. Kraton 6s
  5. Outcast 8s
  6. Outcast 6s
They are 3.5mm, I’ve tried 12.9’s and they snapped too..
I only use stock wheels and tires so it’s not because of heavy meats. It’s probably like ya say, just hamming it for air control and wheelie’s. 🤷‍♂️
