Im pretty sure the rear are longer. I know for sure they are on the kraton and talion and i think they use the same shocks. 63mm front 75mm rear but not 100 percent
The shock shafts are definitely different front to rear. Do you have a 2017 Outcast or a 2018 Outcast? If you have a 2017 Outcast look on page 49 of the manual, left is front shocks and right is rear shocks. If you have a 2018 Outcast, look on page 56 of the manual.Thanks for the reply. I couldn't find much info on the shocks in my manual. I just wanted to order an extra set of shafts to have on stand by.
You did find the part numbers on page 49?It's a 2017. Thanks for the info. All I found was a shock maintenance section but it just said how to fill it and clean it.
Where are you typing it into and what exactly are you looking for?When I type in ar330490 and AR330481, all I get is shock shafts that are 2.5x75 ar330251 and 3.5x63 ar330195. Same same??
I just realized that is a Rustler chassis with an Arrma motor mount, motor, center diff and center diff mount on it.Go 6mm no problems yes you have to make and modify the shock bodies and change all o ings bit I heat treated mine and i. Almost done they are huge.View attachment 17856
