LOVEMYRCMUNNYPIT
I put a HR aluminum mount in and the steering was working fine. Now when I turn my vehicle on the servo is making noise and won’t turn. Any ideas? Thanks.
Is it the stock servo? If so then it probably stripped.
Could be the horn spline is too tall and it's hitting the case? Or the screw is too long and damaged the innards. I've done that before.
To tight, no, but depending on how the output shaft is designed, too long can cause problems. Either strip the threads out of the output shaft, or drive the screw through the gear into the potentiometer it sits on, which destroys the servo. Or of the depth of the cup where the splines are is too deep for your servo, it will drive the horn into the top of the servo case causing it to bind. I've done all those things... I'm not very nice to servos. lol
I’m just trying to learn. Lol. It was the top middle gear in the servo that stripped. I took somebodies suggestion for a quick fix and rotated the gear and that side stripped while I was checking it. So now I’m looking at the upgrade threads.
