6s yes but barely half throttle. Just got it and only on the 2nd run trying to get use to first.
I knew there would be weak spots but I’ve never heard of these breaking bashing hard let along just driving around getting used to the truck. Granted I’ve had this longer b4 breaking then my traxxas ?Damn I ran mine 6S a bunch of times never broke the axel hub, But I did sorta shred the teeth on the front outdrive it seems :\
These trucks man I tell ya, Im starting to regret ever getting into 6s vehicles, I really don't think these are built for this kinda speed and bashing, Theres far too may weak points..
But naa that ain't right or normal that never should broke.. least not that fuckin quick doing nothing.
Date/Time (CST) | Status |
2/8/2019 1:29:30 PM | Holding for Parts |
2/8/2019 10:40:41 AM | Assigned to Technician |
2/7/2019 4:20:19 PM | Product Checked In |
Are these a weak spot or just a mishap if they brake? 2nd run on my new notorious just getting use to the truck not doing anything crazy and the front left broke.View attachment 29754
Have you ever torn your diff apart?How hard are these to change??
Anyone have a write up on the procedure?
All of mine are flat, front, center and rear.I just had a better look at your photo and realized what your talking about. The fronts should be flat at the tip of the dog bone and the rears should be round. If you have one of each, left to right, someone messed up on assembly. Hard to make sense of it though, cause front and rear are 41mm difference in length. Must be from a different rig. Measure the lengths of all four, but mark what came off the front and back. Might help to figure out what's going on.
