SrC
RC is a lifestyle choice
Hospitality Award
- Queens, NYC
- Fireteam
- Infraction
- Limitless
- Kraton 6s
- Mojave
- Notorious
- Outcast 6s
- Typhon TLR
I always felt lipos run at their best after only 2 cycles, if that. Just need to warm cycle them maybe twice. And I think their performance doesn't really get much better after that. Either you got a good matched batch of Lipo cells out the box, or not. Just me. Cells being well balanced, is more important to run time after that.Brand new packs won’t give you the max runtime. You need to break them in. After 10 or so runs they will last longer.
Unlike old school Nims and Nicads from the last Century that needed much cycling for max cap. Way diff chemistry. Almost doubling its capacity potential at times. Due to inherent charge memory.
There is Zero memory effect with Lipo cells. In theory they should perform the same after the first charge cycle. Which burns off the "Mfr'ing "Paste" upon its first cycle discharge.
Edit:
My research showed that the HW card only works for programming with the older Legacy Arrma branded BLX ESC's.
The Firma ESC's require the Firma Programmer. For Parameter settings as well as F/W updtaes IF any available.
I don't think that F/W support is ongoing however for the end user as of late, depending on which model Firma ESC.
Maybe at the Factory is exclusively where F/W tweaks occur. IDK.
Some retail Firma's and other RTR HH brands (TLR) that use RTR Firma ESC's have different F/W. And parameter values. Despite same appearance and model Specs.
^^^it will work on the ESC but it wont unlock the LVC setting.
