Red92rs
- BigRock
- Kraton 6s
- Senton 3s
So my Big Rock has done this twice now. I take it out, at first its fine. After a few minutes the throttle becomes real laggy on initial pull. Eventually I go to pull throttle and the it just stops. I have blinking green light on the ESC. Is this a bad ESC? I run on mostly mowed grass so not hitting long sustained speeds. This takes about 6 or 7 minutes of running or about a 1/4 of a pack on a full charge. Using the Spektrum smart 50C 5000mah 3s batteries. I have the 15tooth pinion in, but am running the larger Duratrax belted lockup MTs. Thoughts?
