Nice one ,as you can probably tell im new to the hobby so trying to find my way are theyre any particular batteries you would recomend for general bashing with a good bit of grunt as well as a bit of longevity in runtime any advice is appreciated cheersYes, overpriced snake-oil for bashers but there is a very limited use for these for high speed runners.
They do prevent drops in voltage when accelerating to the max capability for both ESC and battery.
Unless you plan to go past 100 mph+ these are useless as they will do nothing other than empty your pockets.
Below, he is going into a littlebit in the first 10 min. If you do not understand the graph and discussion topwards the end you won't ever have to use these (no offense intended). You have to have a datalogger integrated into the ESC to get any meaningful result.
Thanks for th at im in tthe U.K and oretty new to brushless ran nitro some years back then got the bug again now got 6s outcast fully CRCU kitted i have some overlander sport track 3s 4500mah but want to have the option to run 4s also. single pack or x2 ??
Appreciate the advice so nice one pal
Thanks for that guys massive help to this journeyman ill get some prices and let you know i like the sound of St chalkys choice as my outcast is full CRCU and carrying a little weight im also punch 5 so i think they will be my first choice thanks again guys ???HK are out of stock of the HD battery or were earlier in the week so I tried the new Rapid hardcase, 5500mah 140C which arrived Wednesday. Must say I'm impressed at the punch on these Rapids, got no trouble at even already high speeds of getting it to wheelie on my fairly heavy M2C'd Kraton 6S, and only punch level 5 on the ESC.
Thanks for your help ill get on MSUK when i finish work cheers??@Abandy that's a "cap pack" and not a battery so you don't want those.
I've bought all my batteries from Hobbyking (UK warehouse) and I use Turnigy (various types/model names).
Link: https://hobbyking.com/en_us/batteries-chargers/batteries/lipo.html?___store=en_us
Personally I always like to run one pack rather than two whenever possible.
Sign up to the MSUK forum also when you've time as it's a good general RC forum with most members UK based so if looking for advice for where to buy from it's a better source of info.
Again nice one ill subscribe when finish work i have the same issue with wheelies but like the short wheelbase in the air started a savi gs pot for a kraton or a typhon cant make mind up yet truggified typhon or kraton ill get my head around the battery choice for now though nice notorious by the way i am also looking for some cooling for the motor your set up looks nice cheers again???this is a UK basher with a Notorious giving the Rapids a run. Main thing to be aware of with them is that you'll likely need to release the little tab on the battery cover so that it can come up a bit higher as they are quite tall batteries being hardcase. The Turnigy HD being softcase go straight in no problem but no stock of them at the mo. The HD i think are excellent for the money but at only 9 quid more per battery I'll happily buy the Rapids again
Ive kind of decided to go down the turnigy route and after scouring hobbykings site last night put an order in for some 5500 140c rapids was gonna ho with a new charger aswell but the one i wanted was out of stock so will stick with the imax for now thanks for your advice ?I should put in a vote for Turnigy also. I have several smaller ones for air models but for my ground vehicles I purchased a couple of the Heavy Duty line from Hobby King. These have impressed me as well. Unfortunately I just found a 4s one puffed slightly because I regrettably left it charged for a long time and this is my fault. Both are soft packs with blue shrink. 4s . 5000mah . 60-120c discharge
?????If its within your budget when the time comes, I can recommend this charger SkyRC T200
My Max8 came with a cap pack. Considering it's free, would you still just leave it in the box? I didn't bother with it so far, but this thread reminded me..Yes, overpriced snake-oil for bashers but there is a very limited use for these for high speed runners.
I'm not sure those are the best choice. Did you deliberately go for a 2P pack?Ive kind of decided to go down the turnigy route and after scouring hobbykings site last night put an order in for some 5500 140c rapids was gonna ho with a new charger aswell but the one i wanted was out of stock so will stick with the imax for now thanks for your advice ?
I'm using the ESC in a SWB Truck (MT410), so no wild speeds.
You don't need even half of that C-Rating. And I suspect having twice as many cells will not help in the durability department.
