If this is your first time taking it apart, take a pic of how it comes from the factory. Perfect reference tool.
I would strongly suggest removing the diff assembly and cleaning it properly because if you have remaining FOD, you risk destroying the new gear.
Dang those wheels look really strange. The offset seems way too small. If that the 6x30 14mm inserts?Forgot the pics so someone can see if the tires are gonna be a problem before I run it.
Yes, that is the set of adaptors I got in addition to the tiresDid you get part number 6347-00
Can you take a pic of the insert off of the wheel? See what depth it is. Do you have a set of metric calipers?Yes, that is the set of adaptors I got in addition to the tires
Says on the package 6355-00 not 6347-00I don’t have calipers but I’ll get a pic of it taken off the wheel if that will help?
