Kraton Part # compatible?
5AFE CRACKER
Hi so I went and purchased
HR AON21MA01 aluminum steering blocks I then find part # AON21M01 also aluminum steering blocks I have the Kraton 6sV4 am I ok with AON21MA01? Hope I didn't make a mistake in ordering hobby shop was all out of stock for the AON21M01 also what's the difference? Parts #s are so close only the "A" is different between the 2 any help would be greatly appreciated thanks
https://hot-racing.com/?partnumber=AON21MA01;c=938
Website states product replaces AR330187
Exploded view shows me part #AR330197 I can't find part #AR330187 is this a mistake?
The 21M01 would be for the v4 kraton. The 21MA01 would fit the likes of the limitless, infraction and typhon 6s.
As per website:
Hot Racing heavy duty aluminum steering blocks (axle carriers) with carbon fiber steering arms for the 1/8 Arrma Kraton BLX, Senton BLX, Talion BLX, and Typhon BLX. See vehicle model compatibility in comments below.
FEATURES:
- CNC machined aluminum, anodized black
- 4mm carbon fiber steering arms
- Aluminum hub nuts with Delrin cups and o-ring position locks
- Heavy duty rubber sealed bearings, with oversized inner bearings
YOU WILL RECEIVE:
- One (1) left aluminum axle carrier with with carbon fiber steering arms
- One (1) right aluminum axle carrier with with carbon fiber steering arms
- Four (4) aluminum hub nuts with Delrin cups and o-ring position locks
- Two (2) 8x16x5mm rubber shielded outer bearings
- Two (2) 15x24x5mm rubber shielded inner bearings
REQUIREMENTS:
- 5mm Hex wrench
- Installation
- Recommended to use medium thread lock on screws
- Arrma vehicle that uses the front steering blocks from Arrma AR330187. Does NOT fit vehicles that use Arrma AR330403.
SPECIFICATIONS:
- Weight: 45g per steering block
COMMENTS:
- Replaces Arrma AR330187 front steering blocks
- Replacement parts include, Hot Racing: AON21G (CF arms), AON21N02 (hub nuts)
- Known to fit the following Arrma vehicle part numbers. The vehicle part number can be found on Arrma's website, the literature that came with the vehicle, or on the vehicle box around the barcode. If a vehicle is marked below with the word "optional, " then the part may fit, but may require some modification.
- Infraction: ARA109001
- Limitless: ARA109011
- Mojave ARA106058T1, ARA106058T2
- Kraton: AR106005
- Senton: AR106007, AR102654, AR102673
- Talion: AR106003, AR106014, AR106030 (2018 V3 model), ARA106048 (V4)
- Typhon: AR106001, AR106013, AR106028, ARA106046
description revised by: SN May 6, 2019
If you reference the kraton model number that should return v3 or older. You said you have a v4 and the v4 model number is different. I was in the same boat when I ordered those pieces for my v4 kraton and my infraction build.
From what I could find these should be the same just that 1 is older stock and the other is newer stock. Specs look identical for both so I'm thinking I will be ok ? I will let y'all know once received
I bought the 21M01s as designed for the v4 (lucky me) and they work great. I could of easily done the same thing.
You would have some extra space between the back of the wheel hex and the bearing. The wheel axles on the kraton are longer than the ones used on the typhon/limitless/infraction.
Will they fit? Yes. But you will end up needing to do something about the wheel hex gap.
