Part time reverse?
TheGlack
Brand new V4 Kraton. Already reset the esc but no change...... reverse only works when it wants to
roondog
Houston, TX
Senton
Are you at 100%? Reverse will only work when truck is stopped. Are you fully stopped and it's not working?
Sledgehog
New Hampshire, USA
Talion
Reset and rebind the transmitter maybe? Should be instructions to do so in the manual or on the Spektrum website. (still not sure why they went with those crappy things when the Tactic worked great)
crimsonfancy
A guy that won't give up easily.
South Louisiana
BigRock 4x4, Granite, Kraton 6s, Mojave, Notorious, Talion, Typhon 6s
Only trouble I've heard about losing reverse is when the switch is turned down to less than 100% power.
Disappointing when Traxxas vxl system can be tuned to lower the speed wherever even with bluetooth connectivity.
Captain Dirt
Need more RC
Murica
Granite, Kraton 6s, Voltage
Yep, if it's moving, the reverse acts as a brake, once it stops it kicks into reverse.
TheGlack
Fully stopped, and it doesn’t matter which setting I’m on
TheGlack
Already did that too
Jeremy in WI
Milwaukee
4x4-Mega
Is there a dual rate knob for the throttle on the new transmitters? If that isn't centered to the liking of the receiver it can get hard to catch reverse.
Sledgehog
New Hampshire, USA
Talion
This may be a stupid question as I'm not familiar with the spektrum they've included with the v4s or if they changed anything on the esc but... it doesn't have that thing where you have to push the trigger forward twice to activate reverse does it? I understand some electronics use that method like the hobbywing esc I just tossed in my tlr. Probably not the case but never hurts to ask I guess.
slick2500
Will work for beer.
Staff member
Rapid City, SD
Outcast 6s, Senton, Typhon 3s
I actually think all rcs are set this way, you have to double tap to get reverse.
I personally think this is an esc related issue and has absolutely nothing to do with the radio. I have seen a few others with this issue and I myself had this issue with my original BLX185 in my Outcast I would have to hit the trigger like 3-4 times before it would start to reverse, and usually by the 3rd time I was like dufuq and would smash it so the truck goes flying backwards........ I replaced my original rx with a Tactic TR325 when it fried because the rx box leaked and the brakes still took 3-4 taps before they would engage. That esc eventually let out the 4 flashing leds of death. The replacement that Horizon sent me the reverse works on the second pull like it should.
crimsonfancy
South Louisiana
Cheapbastard
Military Veteran
funny page 21 shows IC5 connector and still shows Tactic radio profile. Should work fine just the same.
I saw that also it is just the same even though they show the Tactic transmitter it's just recognizing throttle trigger positions no matter the transmitter when doing throttle setup.
Create account
Log in
