Kraton @Paulie found diff shims
Corider
Castle Rock iColorado
  1. PaulieActive Member
    The Team Durango planetary shims seem to be sold out everywhere. I bought this kit and the shims work. It contains both planetary and satellite gear shims.
    Part# MUGE0206
    Mugen Seiki Differential Washer Set
    Five 5x18mm diff washers (0.2mm thick)
    Ten 3.5x12mm diff washers (.02mm thick)
    I am not sure how to Give Paulie Props for this but he found this Mugen diff shim pack that works. I have been searching for Planetary shims all over with no luck. Ordered some up as soon as I saw his post,
    Thank you Paulie!!
    Part# MUGE0206
    Thank you Paulie!!
If you want planetary shims for inside the diff just google for shims 5x15x0.3mm
There are tons everywhere
Thanks for the heads up. I have been searching for 5x18 with the part number called out in TomP's video. Those are sold out everywhere I have looked. Glad to know there are other options and 5x15 will work
