Talion Picked up a v3 6s slider.
MFM
Beast mode activated
ArrmaForum Fan
Rig of the Month Winner
New York
  2. Infraction
  3. Kraton 6s
  4. Mojave
  5. Mojave EXB
  6. Notorious
  7. Senton 6s
  8. Talion
  9. Typhon 6s
Ima Mojave / senton 6 kinda guy. What would it take to convert this talion slider to a senton or like a mini Mojave? I have enough poop to make this thing fly! What’s some neat tricks to these. Need to to know anything for a mojave then hit me up;-)
No idea. Or are you telling me? Can’t I toss senton body mounts and bumpers center diff roll cage etc...
It’s not the current v
What other arrma body’s can I rock on this
I didn’t see the second body post in this pic
You can run any body as long as you switch the posts I think
Unless you are switching to short wheelbase
Yeah I saw this and thought the senton posts would
Be high enough to clear the towers. Are these talion running wider arms than the senton or the same.
thoight I read somewhere last year when I had my senton that they share more than diffs and bulkheads.... shocks same? Arms?
Yeah, that slider is a v3 at minimum. A Kraton LWB chassis. Select a body accordingly. Body post mounts of different types can be fitted to make things work. Is the Kraton Wing missing? I don't see it there. I only see the wing mounts.
It is v3. So any body will work w appropriate mounts ? Are the arms wider?
6S Kraton is wider and longer than a 6S Senton. Fitting a Senton body will be rough. Migt have better luck with Mojave body. Not sure. :unsure: You can drop in a Kraton body easiest.
Wonder if the infraction body would work. Pricey for it not to...
seen one w proline chevy body...
So here we are! Got the jconcepts finisher body on my newly stretched talion! Tried the Mojave hybrid and didn’t like the outcome. For now we got the Mojave chasis. 1/7 scale talion 6s.... more to come. Really liking this thing a lot. Love the cool sparks from the scorched titanium chasis slapping the ground!! Def badass!
