bashingpumpkins
I just bought an Outcast after getting a Kraton 4S as my first RC at the start of the summer. It looks like it is a V1 or V2, and it is kind of beat up. One of the tires is blown out, so I will need to get some new wheels before really testing it out.
My initial impression after running it on 4S is that it is slightly slower than the K4S on the same battery, so it should move pretty well on 6S. I noticed it occasionally wouldn’t turn left, and the suspension wouldn’t rebound after pressing it down. It turned out that the previous owner cranked down on the pillow ball caps so hard that the hub wouldn’t move. Luckily, I fixed it before the servo was completely destroyed. I also cobbled together some adapters to check the two 3s batteries it came with on my charger. One was at 3.8 on all cells, and the other battery was at 3.94. The seller used those batteries to show me the car before I bought it, so hopefully that quick run didn’t cause much damage.
It is surprising how dimensionally similar the Outcast 6S is to the Kraton 4S. The wheelbase and ride height are almost the same, but the Outcast is around an inch wider. The K4S is about 8.3 lbs without battery, and the Outcast was 10.9 lbs
Other than getting new wheels, it looks like I should shim and grease the diffs. Does anyone have recommendations for wheels, or other things to check before running it more?
