Now I'm using hr metal spur gear. Is it ok to leave it dry? Package said that use some thread lock or some thing. Is it a must or better to leave it dry?I suggest you leave it dry. I've never lubricated the pinion/spur and never had an issue.
Hot Racing ATF15H is this the pad that can be used with hr metal spur?If you insist on lubing the pinion and spur, which isn’t necessary at all, use the chapstick method mentioned above, or some type of dry lube. DO NOT USE GREASE!!!
YesHot Racing ATF15H is this the pad that can be used with hr metal spur?
