BigMacDaddio
- BigRock
I changed the pinion on my BRCC to a 20t pinion to see how different to normal it would perform. I changed it to the 20t holes but when I put the spur in the mesh seemed very tight. When I ran it, it would run for a bit then when I stopped and tried to go again it seemed like it was bound up and wouldn't move. I checked the motor and it was very hot after only a small amount of time. Would the tight mesh cause this or would the heat be the the nature of running a bigger pinion? Just wondering if I should drill out the holes a little to loosen the mesh or just go back to the 15t.
