You have to put new thread lock on each time you remove the grub screw. Clean the pinion and grub screw with brake parts cleaner, it's less than $2 at Walmart, then apply new thread lock to the grub screw.Pinion slides inward on motor shaft. It's the stock 13t pinion with the original Blue locktight. What should I do?
How did I forget to mention that? Thanks for catching that btw.AND LET IT SIT FOR A DAY TO CURE!
So many people apply forget to let dry and woops it slipped off again :\
Yeah I have crs really bad.Easy peazy to forget
