Sure you’re tightening the grub enough?I have Kraton 8s stock, the stock gear get loose and damaged motor mount. I get a new arrma 23t gear and put blue glue and left for 24 hrs and in the second run get loose again what I can do?
Yes very tight.Sure you’re tightening the grub enough?
Thanks.Loctite is the problem.
Use this and leave it for 24hrs and will never come off again when running the car .
any update did you fix it ? my gear got loose alsoI have Kraton 8s stock, the stock gear get loose and damaged motor mount. I get a new arrma 23t gear and put blue glue and left for 24 hrs and in the second run get loose again what I can do?
did you try the red tread lock ? or maybe a new grub screw or new gear ?No still getting lose
sorry im looking everywhere how to fix the problem and some ppl are saying they fix it by buying new geardid you try the red tread lock ? or maybe a new grub screw or new gear ?
sorry im soo new what you mean red on the shaft ?I use red on the shaft and blue on the set screw. I always make sure to clean pinion, screw and motor shaft in alcohol, and makes sure the set screw can go the whole way in the pinion. If you have used thread lock before, it hinders the screw in going the whole way in, mo matter how hard you are tightened it.
Red loctitesorry im soo new what you mean red on the shaft ?
