ArrmaGraniteState603
- Granite
Granite 4x4 3S BLX
Hey Guys,
Attached are some pictures of my stock 15T pinion gear that came with the Granite. Looks stripped to me no? I had to drill out the set screw to get it out, pain in the butt, you can see the collateral damage to the top of the motor. I've gone through 3 composite spur gears so far so upgraded to steel. I am currently looking to order a new pinion. Running into some compatibility questions.
1. Seems the lower tooth numer I go I'll lose a little bit of top speed (thats fine) but the motor will run cooler and I might get more life out of my batteries (great). I was looking at a 13T.
2. Several different options on amazon, I want to make sure I get the right size. Would a 32P 15T 1\8in hole work? P is the pitch of the gears? T is obviously number of teeth, hole is obviously the size of the hole for the motor driveshaft, what size hole and P is the stock granite gearing?
3. What does mod 0.8 indicate?
4. I see 12T's available but the motor mount only has holes for 13,15,20,26. Am I bound to those sizes only?
5. Side question, if I'm in sand most of the time should my slipper clutch be as tight as possible or a little looser than that to allow for play.
**I am aware i'll need to mesh the new pinion to the spur gear, from what I've read make sure the gears are at the same level and set it. Any advice there would be appreciated too.
*** Went black with the wheels, what do you think?
Thanks guys!
Hey Guys,
Thanks guys!
