1260kv or 1650kv?The castle mmx8 and 1717 motor came in today, what would be your guys rec on pinion gear , it has a stock infraction diff in it with whatever spur gear it comes with stock..
I’d buy this set to experiment with different sizes - watch speed and heat closely. Look at the logs. They’re cheap, decent pinions. Once you make a decision, then buy a Tekno pinion of that size. Pricey but it’ll last forever.1650 6s and just bashing.
Because Spektrum uses proprietary pinions.Is there a reason why the pinion isn't sliding on the new motor, shaft looks the same and I'm trying to put the 20 tooth gear that came with talion on it...
Spektrum stuff is decent for RTR quality. It’s just that RTR quality isn’t great.I'm starting to highly dislike spectrum, the servo horn and now this SMH
Where can I get the teknos ones thanks!I’d buy this set to experiment with different sizes - watch speed and heat closely. Look at the logs. They’re cheap, decent pinions. Once you make a decision, then buy a Tekno pinion of that size. Pricey but it’ll last forever.
AMOGOT Metal Steel M1 Pinion Gear Sets 21T 22T 23T 24T 25T 5mm Shaft Motor Gears with Hex Key for 1/10 RC Brushless Brush Motor https://a.co/d/5jxhF1d
P.S. Make sure to set your motor temp cutoff in the settings. I choose 170F since motor damage can happen above 180F.
Tekno. Amain. Horizon hobby. Etc.Where can I get the teknos ones thanks!
