SrC
RC is a lifestyle choice
Hospitality Award
- Queens, NYC
- Fireteam
- Infraction
- Limitless
- Kraton 6s
- Mojave
- Notorious
- Outcast 6s
- Typhon TLR
I know exactly what it is. I have this. It is NOT new.Just remember this isn't "standard TL" i know he calls it TL in vid lol
I have so much of the LockTite/Permatex products. Used on my scale cars for years and at the Dealer.
I also wrench and custom build Bicycles. My other more expensive Hobby. I use 680 on my the Bottom bracket of my bikes for press fit hubs. Very familiar with it.
For RC not necessary.
@M240i_bandit, It seems you are NOT comfortable around setcscrews,, Thread locker and torqueing them yet. Proper Handled Hex drivers are your friend. (MIP) Thread locker is Not Retaining Compound for starters. I change out pinions frequently, testing different Ratios and never have problems with them.
Improperly installing a pinion, with bad tools and neglect overall will cause a loose pinion.
If you prefer to install a setscrew looser than it should be because you fear "over tightening and rounding out the hex", and use compound or TL on the shaft to compensate, that is absolutely incorrect.
FWIW, running in the wet will rust out the pinion and grub screws. May be part of the problem. IDK. They are consumable parts. Best to use new setscrews every so often. Grind the bottom of setscrews a bit for a better bite at the shaft. Keep them in bulk in your tool box.
There is a difference between quality Upgrade pinions and the cheap Arrma's FWIW. You pay for what you get with these.
(Think Tekno, RRP, Saga.)
