pinion questions
Discussion in 'Chassis & Drivetrain' started by Motherfocker, May 14, 2018.
  1. Motherfocker
    Motherfocker New Member
    Mar 23, 2018
    Arrma RC's:
    Outcast
    i put in the 16 t pinion for Arrma Outcast and it goes way faster but sometimes when i smash trigger at slow speed it sounds and feels like it skips a gear and just cogs out and doesn't move. is my mesh not good or is it a side effect from higher gearing?
  2. olds97_lss
    olds97_lss Premium Member!
    Dec 14, 2016
    178
    56
    More than likely it's a hair too tall of gearing for either your lipo's or ESC, especially if your running 4S.
    I noticed the same thing on my stampede 4x4 when I geared it up a bit to get some more speed out of it when running 2S. It stutters off the line if I pin it. When running lower voltage (like 2S on a single pack truck or 4S on a dual pack truck), the motor tries pulling more amps than can be supplied. I dropped my pinion down a tooth and my spur down 2 teeth to kind of get the most speed I can while not causing the motor to stutter off the line.
    Tires would also play into it. More rotating mass and larger diameter is effectively gearing up as well. Not saying that's your issue, just mentioning it because it matters.
  3. Paultro84
    Paultro84 Well-Known Member
    Jan 24, 2018
    294
    118
    Arrma RC's:
    Outcast
    Make sure your set screw didn't come loose. Mine did 10 minutes ago and it smoked my pinion gear. 20180515_112936.jpg
  4. Motherfocker
    Mar 23, 2018
    Arrma RC's:
    Outcast
    ya my grub screw is good. i loctite it everytime. i never have issues with it comming off. im just wondering if my gear mesh is a tad to tight. im getting heat issues on motor with fan on it after only 5mins. im running 6s with 35c 8000ma lipos so i have the juice. im leaning towards tight gearing. any thoughts?
  5. olds97_lss
    Dec 14, 2016
    178
    56
    Could be too tight, tires too big, terrain too harsh, combined with being geared at it's limit, any of of those could cause heat issues.
    Running in a concrete skate park with short bursts of 1/2 to 3/4 throttle probably works it a lot less than running WOT in some 2-4" tall grass.
    From what I understand, hot motor usually means undergeared (too many RPM's), hot ESC usually means overgeared (too much current draw). For a stuttering issue, I'm going to guess either over geared causing the ESC to try pulling too many amps or C rating too low.
  • Welcome to Arrma Forum
  • Disclaimer
