- Williamsburg, Kentucky
- BigRock
- Granite
- Mojave
- Senton 3s
- Vendetta
Soooo, after realizing my Team Corally Python XP 6s had a ridiculously huge pinion on it and wanting to go to something a little closer to the stock flavor, I proceeded with taking the motor out of its mount and had my handy dandy Pinion puller and heat gun ready to go. Everything was going swimmingly until realizing this pinion was so large that you can't extricate the screws from the motor mounting plate because they jam into the pinion. Gotta love 2nd hand rigs. Well, I finally manage to get that screw out and of course because the pinion is ridiculously large even without the screws, the mounting plate wiggles around between the motor and pinion but cannot come free to give the pinon puller a clear shot at mounting on properly. No bother, let's go ahead and remove the set screw.
Hit the set crew with the heat gun and it breaks loose with a little bit of persuasion but it's not backing out. Cool. It's stripped. Or is it? Grabbed my drill with my hex tip and try to back out the set screw. Sure enough, it's not coming out. Alright, no big loss. Don't really think I'm going to need a 21t pinion as I'm not tryna do any Raz Shifrin s*** here and value my eyebrows. So now we're stuck with no way to get good leverage on this thing. Pinion puller can't mount up due to the motor mounting plate. So far I've broken three screw drivers and my pinion puller trying to get it off anyway. What's the next step? I do have a rotary tool and am considering just cutting the gear in half. Am I overlooking a better solution?
