Meffen1023
so my stock pinion striped . I got the set screw out now I can’t get it off the shaft . I tried heating the shaft up with my soldering iron and a heat gun and it budge !
Thanks that little set screw came loose and every hex I had wouldn't fit either to small or to big.itz just sliding back and forth on the shaft.Stock is a 2mm . Now I have a tekno pinion on it that is 2.5 .
