ndoppes
- Senton 6s
hello, new to the forum and hoping to get some help. I tried searching this topic and didn't come up with much, I apologize if this has been discussed already and I wasn't able to find the info.
I recently bought a 3S senton BLX and rounded a spur on my 8th pack. I am only running 2S batteries and really I've been driving the truck at 3/4 power, I'm new to this game and she is pretty squirelly at full pull haha. Anyhow I live out in the middle of no where and I had to drive 2 hrs to get a new spur. the guy at the shop said to make sure I set the gear mesh right. I proceeded to watch toturials on gear mesh. I then went to install the new spur and realized the motor is fixed in its motor mount.I attempted to set the spur anyway with a piece of paper. I buttoned everything back up and set the slipper about 3/4 out.
With fresh battery I went for a test, I made it a half a pack before it started sounding funny, I pulled the motor apart and sure as hell the gear was already toast. Im pretty frustrated with the money I spent to have only run 8.5 packs and 2 spur gears toast. Any thoughts or help will be appreciated. slipper to tight? bad mesh? how can the mesh even be adjusted with a fixed mount?
I have a hot racing metal spur in the mail, will I need to run a hardened pinion with 2S packs and with the metal setup what is the next weak link?
Thanks again in advance, the truck is a blast when she's dialed. As of right now its a pretty expensive paper weight....
