Yours came with a fan?Did you keep the fan it came wit or did you buy a new fan and if so which fan do you recommend
Are you running stock electronics other than motor fans? Esc fan stock?To gain speed you increase pinion size or decrease spur size. Just start with a larger pinion as most do. Just watch you motor mounts ability to adjust it's mesh with different spur and Pinon combinations. Watch your temps with possible overgearing. I run 20T pinion and stock spur on my Kraton 6s. I wouldn't go higher. I have motor fans to keep things cool.
