48p or 32http://www.robinsonracing.com/catalog/5mm_pinion.html#12xx
Click the 1 module link at the top of the page if it doesn't go to them automatically
No mod 1.48p or 32
ThanksNo mod 1.
Thanks for info trying to decide if I should go with a 17 or 18 toothYeah, 1M M1 Mod1 Module 1, all mean the same thing. Fairly standard on 1/8th scale stuff. 1/10th tend to use 32p/mod .8 or finer.
You can't go wrong with either. I went with 18 on mine.Thanks for info trying to decide if I should go with a 17 or 18 tooth
Thanks brother. Great videosYou can't go wrong with either. I went with 18 on mine.
Great site. Thank youThe price on the MOD1 5mm pinion gears can vary quite a bit. Here's some really good pricing on some heavy duty steel ones - MOD 1 5mm bore pinion gears
Brian
Thanks, man!?Thanks brother. Great videos
Integy? Do they hold up ok?The price on the MOD1 5mm pinion gears can vary quite a bit. Here's some really good pricing on some heavy duty steel ones - MOD 1 5mm bore pinion gears
Brian
Yes. Made of steel and are heavy duty.Integy? Do they hold up ok?
