Typhon Plastic diff ring gears
beaker441
Well the 3S BLX line is on complete backorder (from what I suspect is a Tactic to Spektrum radio update). During this time I have researched the snot out of the Typhon 3S and I’m curious how everyone's plastic diff rings have fared. Any breakage, stripping, or premature ware?
Also, how do the plastic driveshafts hold up to 3S batteries?
Cheers all!
Driveshafts on my BRCC break all the time probably because of 2.8 size tires i would imagine smaller typhon tires putting less stress on them, sometimes i can get away with just putting the metel yoke back into the hole and use a heat gun to shrink it and other times its just too wore out, other then that ive only broke 1 input gear and a few spurs
the plastic diff gears have held up fine, you would see many reports on here if people had issues.
I've broke only a couple and that was due to a very tight slipper and some bad landings. The wheel driveshafts I go through like crap though a goose.
