Broke the rear diff the other day when I landed with apparently too high wheel speed.
The internal diff gears are fine, it's the input gear and output ring gear that are both stripped.
I'm replacing the gears now . I'm finding that the mesh is far too tight and I cannot get smooth action out of them no matter how hard I push the bearing onto the input gear and even when I remove the spacer from the diff housing.
My question is, is this normal? Will the plastic gears chew themselves up while driving until the mesh is correct? Or have I done something wrong in the assembly? It seems very simple and straightforward but I suppose I could have made a mistake.
Please somebody with experience guide me! I don't want to burn through another diff!
Jrod
Jrod
