https://polocreations.com/products/...-led-headlights-lights?variant=31098501922902Not sure how much help ill be as i have not done the kraton.. Which kit did u get?
I installed the Polo Creations light kit in my Felony.
No instructions, nothing on their website.
It took much longer than I expected - much time was spent planning / figuring out the best way to mount things.
I ended up figuring it out myself ..... drilling holes to mount lights and epoxy / shoegoo to hold things in place.
I also found the wiring on the light kit was way too long - I ended up cutting and re-soldering all wire harnesses (I hate excess wire as it is hard to secure and looks terrible).
Used foil tape to secure the wiring to the inside of the body.
Well at least you guys gotta kit I've been agonizing over a light setup for my Kratorious and might literally have to build light buckets from aluminum sheet and lenses from plexi for front amber running lights. Ugh.
Here is my installation - i am running the C8 body on the Felony now, so no pics of it on the chassis.
I am into lights on the Infraction and Felony which I did install Polo's. Not so much with the bashers because they take a beating where the on-raod cars do not.
HOWEVER, I find lights on the bashers needing to know the direction I am going/pointing and especially when I am in very loose, cloudy dirt or evening.
My Kraton I did my own. I made it simple to take hits and crashes. I do not like installing lights in the body of a basher so I install them in the body for protection on 4x4 bashers unless it is a basher style light bar. Kraton I did two. Front white led lights cut into the bumper and the buckets came from a user here who uploaded them to Thingiverse but I had to get someone to print them. Rear red came from Polo creations for the Losi DB Pro which I fibrated to fit under the Kraton wing mount. With the fall/winter months and fast sunset these lights, although simple really helps me eyeball where I am going without needing to focus so hard if it is the front or back of the RC especially at a distance just look for the color light. Both ends have held of the bashing, jumping, crashing well!
Here are the buckets. The user posted them for the Big Rock which I did cut them in for my Big Rock and added Polo amber lights I requested from him...amber looks cool see my rig below...almost went that way on the Kraton, again same buckets I used for the Kraton
Buckets:
https://www.thingiverse.com/thing:4876129
View attachment 189130View attachment 189131
