Found the problem. Diffs are fine.
Thanks I will check it again. I have the Tekno shims and couldn’t add another it was too tight. I checked this when I shimed the diffs.that'll do it. you should add another bearing shim to the gear side when you put it back together. it closes the mesh on those gears a tad. supposed to help keep that from happening again.
https://www.amazon.com/gp/product/B0034ZBO5S?tag=arrma-20&creativeASIN=B0034ZBO5S
or
https://www.amazon.com/gp/product/B00F8OQ2NC?tag=arrma-20&creativeASIN=B00F8OQ2NC
Input gear is fine. I will regrease it I remove any metal fragments. I have tow replacements on the way.That would definitely do it. Better make sure the input gear is fine. Damage like that can leave debris in the diff that could eat away at the input gear as well.
